tschak909 Posted December 2, 2020 Share Posted December 2, 2020 #Atari8bit Any assembler coders? Anyone want to help out with #FujiNet's CIO handler? There are three issues that I need help with as I work on the firmware (ESP32) side. Add Binary Load File support https://github.com/FujiNetWIFI/fujinet-nhandler/issues/1 Add NOTE/POINT support https://github.com/FujiNetWIFI/fujinet-nhandler/issues/2 Make code relocatable again. https://github.com/FujiNetWIFI/fujinet-nhandler/issues/3 Add burst mode I/O https://github.com/FujiNetWIFI/fujinet-nhandler/issues/4 Quote Link to comment Share on other sites More sharing options...
Alfred Posted December 29, 2020 Share Posted December 29, 2020 (edited) Is there a document that outlines what functions are available to the N: driver on the host side ? I looked at the GitHub doc about SIO devices $70-$71 but it's fairly sparse. Things like what device (SMB server? FTP?) and what specific commands and their format are exposed ? Also the exact details of the transfer protocol between the FujiNet device and the N:. I'm thinking it's changed a bit since I last tinkered with it. Edited December 29, 2020 by Alfred Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 29, 2020 Author Share Posted December 29, 2020 25 minutes ago, Alfred said: Is there a document that outlines what functions are available to the N: driver on the host side ? I looked at the GitHub doc about SIO devices $70-$71 but it's fairly sparse. Things like what device (SMB server? FTP?) and what specific commands and their format are exposed ? Also the exact details of the transfer protocol between the FujiNet device and the N:. I'm thinking it's changed a bit since I last tinkered with it. The fundamentals haven't changed, the current code as it is right now is at: https://github.com/FujiNetWIFI/fujinet-nhandler/tree/master/handler The N: device SIO commands are documented here: https://github.com/FujiNetWIFI/fujinet-nhandler/tree/master/handler The CIO commands are here: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/CIO-Commands-for-N-Device An example program that uses the SIO: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/A-Simple-NetCat-Program And the BURST branch of nhandler has a burst mode that was in the middle of being debugged. https://github.com/FujiNetWIFI/fujinet-nhandler/blob/burst/handler/src/ndev.s#L233 -Thom Quote Link to comment Share on other sites More sharing options...
Alfred Posted December 30, 2020 Share Posted December 30, 2020 That's just the handler source, not documentation. Like what values are permissible for buffer sizes etc. How you turn the flow on/off etc. Valid commands, that sort of thing. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 30, 2020 Author Share Posted December 30, 2020 6 minutes ago, Alfred said: That's just the handler source, not documentation. Like what values are permissible for buffer sizes etc. How you turn the flow on/off etc. Valid commands, that sort of thing. oh shit, I pasted one of the links twice, sorry! The SIO commands: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/SIO-Commands-for-Device-IDs-%2471-to-%2478 -Thom Quote Link to comment Share on other sites More sharing options...
