+Andrew Davie Posted January 9, 2021 Share Posted January 9, 2021 A few comments/issues... Here we see instead of "PlusCart(+)" as the network ID, we see "ESP_2E8CE2". I was able to connect to it, though - it was definitely the PlusCart. On the second attempt, it was shown as "PlusCart(+)". Perhaps the manual needs updating to reflect the name may be different. First, "module" is the correct spelling. It wasn't clear what/where the "Info Button" was. Perhaps this should clarify you need to go back to the main page and select the configuration info button. Change "send" to "sent". Change "mail" to "email". Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 9, 2021 Share Posted January 9, 2021 (edited) 11 hours ago, Andrew Davie said: A few comments/issues... Here we see instead of "PlusCart(+)" as the network ID, we see "ESP_2E8CE2". I was able to connect to it, though - it was definitely the PlusCart. On the second attempt, it was shown as "PlusCart(+)". Perhaps the manual needs updating to reflect the name may be different. I have shared the PlusStore "Setup" folder with you and you should have write access to the "Manual.txt" file.. 11 hours ago, Andrew Davie said: First, "module" is the correct spelling. It wasn't clear what/where the "Info Button" was. Perhaps this should clarify you need to go back to the main page and select the configuration info button. Change "send" to "sent". Change "mail" to "email". fixed Edited January 9, 2021 by Al_Nafuur Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 9, 2021 Author Share Posted January 9, 2021 20 minutes ago, Al_Nafuur said: I have shared the PlusStore "Setup" folder with you and you should have write access to the "Manual.txt" file.. This, I have just realised, is probably the reason for my increase in reported #files in System Info. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 9, 2021 Share Posted January 9, 2021 3 minutes ago, Andrew Davie said: This, I have just realised, is probably the reason for my increase in reported #files in System Info. there are only 2 files in the PlusStore "Setup" folder.. Link to comment Share on other sites More sharing options...
