InsaneMultitasker
Geneve OS development discussion
Got one, haven't used it any on a Geneve as of yet, got to get it going first. Been working 10 hour days with a 2 hour each way drive, not much free time.
  • Sad 1
19 hours ago, dhe said:
How many folks on here are using a scsi2sd drive on their geneve?
I'm working up to it and trying to create a howto to try to make it easier for others.
I've got one, but I still need to connect it. . .one of my backburner hobby projects.
Tim, is of course helping me on this little project of mine.
So far, I think we might need three sections on drive setup - scsi2sd 5, 5.5 and 6 - each seems to have a bit different options.
[rant] - like everything I touch it ends up being a lot harder then I'd have thunk.
case 1: goteks - existing cabling all wrong, pbox holes in wrong places.
   sunk about 18 hours in to figuring out custom cables, making new holes, figuring out how to copy files.
case 2: scsi2sd 5.5 - tried to communicate on usb, couldn't with cable provider by vendor - samplerzone.com
              tried another cable I had on hand - nada...
            finally ordered another new cable from amazon and I'm connected!
case 3: ide controller - about 10 hour sink in getting this going, and that's with a lot of help from Shift838.
So I've got a couple of hours in to hooking up the scsi2sd - and the only thing accomplished is hooked up USB cable.  😵
What I have learned so far from Tim, is 7.3 has special goodness for interrupts to handle scsi2sd - that wasn't needed for traditional drives.
mys and power will tell you the id your controller is set for and scsmap will tell you what id's you other drives are set to.
In the case of scsi2sd 5.5 - it's a 25 pin connector and the terminator is always on, so it will need to go at the end of the chain.
Screenshots from the PC are easy ;)   POWER and MYS successfully compile with TIC 1.67 and I was able to assemble the code with @mizapf's updated TASM v3.41.   Took me a bit of time to realize that the allegedly common code between the two programs was located in two different files. Silly me.  I've since consolidated and cleaned up the dependencies, now both programs leverage the same routines.  I'm a little wary of MYS though, because it uses a simple gets() input routine to capture format information.  And until a few minutes ago the format confirmation proceeded unless you typed 'N' instead of requiring positive confirmation.  Here's a screenshot of POWER in action.
  • Like 4
The OS Dev thread is a nice catch-all but we probably need a separate topic for Geneve program and utility updates.... Regardless, I put a few things together for release thanks in part to the "extra" hour from the time change this morning  ;)
(1) BLOB - Geneve command line unarchiver/decompressor, may be used standalone or invoked by another program such as Directory Manager.
(2) TIAV2 - Geneve command line viewer for Myart, TI-Artist, and Instance files. Meant to be invoked by Directory Manager but works as a standalone program. I used it as a splashscreen program in my autoexec batch file for a while.
(3) Directory Manager 2.65t - invoke BLOB with 'Y', invoke TIAV2 with 'S'.  Updated help text. Added output path option to decompressor selection. Added some readme text.
I have two folders on my devices that contain programs like BLOB, TIAV2, EDIT, QDE, FED, ASM, LINK, and others.   The two folders are part of my "PATH" so that I can invoke the contents from "anywhere" -and- so that other programs can launch/invoke them.  I strongly recommend that if you have the ability to do so, locate your common utilities and programs in a folder in the search path.
BLOB 1.1 Command Line Unarchiver.zip Directory Manager 2.65t.zip TIAV2 2.0 Viewer.zip
  • Like 4
  • Thanks 3
I was looking at the new MDOS documentation that Tim and Beery released.
Technically, not a MDOS/GeneveOS related question, but are there certain CRU addresses that either the Boot EPROM or MDOS expects particular cards to be located at?
Look at the SCSMAP and REMAP notes in the documentation and that will identify the supported CRU's for hardware selectable CRU devices.
Beery
Right..
I see mention of
>1000   - RAMDISK
>1100   - Myarc HFDC   --- Can you have a floppy and an HFDC?
>1200   - SCSI
>1400,  >1600 and >1700 for RAMDISK
>1800   - TIPI
>1900   - IDE
This is scatter though out the DOCS, it might be helpful to have this consolidated at the beginning of the docs, in one place.  Is the question of, are these addresses fixed in MDOS (and/or bootrom) or can they be moved around?
Also left to the imagination, can you have two RS232's?
I'm trying to think of the person that just spent $900 dollars on a Geneve, where would they start?
Michael / Tim - do either of you know the answer(s)?
47 minutes ago, dhe said:
Right..
I see mention of
>1000   - RAMDISK
>1200   - SCSI
>1800   - TIPI
>1900   - IDE
Yes, you can have a HFDC and a separate floppy controller.  Generally, you would want the HFDC to be at >1000 so it is the bootable device.  I think the DSR will permit above >1100, but it has probably been ages since anyone has had it at anything other than >1000 or >1100.
CRU's are fixed at present. CRU's >1300 (RS232 1/2) and >1500 (RS232 3/4).  I do not know of any present reason to have two RS232 cards in a system unless someone is trying to do some debug code on a running program.
Two RS232's should be possible if the second has been modified.
The person that spent $900 on a Geneve hopefully knows what a Geneve is, and has been to Atariage and followed past and/or present developments.  They will have to start somewhere to acquire software to boot the Geneve unless they have a bootable system when it arrives at their doorstep.  If they are not aware of this website and/or do not find links to this website to ask questions, then they surely are not going to find much to do with their new system and any tweaks to docs will never find them anyways.
Dan,
You are more than free to update the present docs and are encouraged to do so.  It would not hurt to have a fresh set of eyes providing updates to the docs!!!
Addresses are fixed in certain cases for code simplicity and because "that's how it was for years" - oh, and for the native OS, CRU order doesn't matter.  The Geneve OS doesn't scan each card for every DSR call, it simply uses the routine corresponding to the device name and mappings. This is true in both native mode for all operations and GPL mode for level 3 operations.  The only times CRU order come into play are at startup (boot EPROM), the DSR powerup (to determine certain mappings), and ROMPAGE operations.
If you intend to boot from the RAMdisk, that card should live at CRU 0x1400.  This has to do more with the EPROM and OS dependencies.  The Geneve can still run older OS revisions though with recent enhancements and bug fixes, there aren't many "good" reasons to do so.  The TIMODE2 command uses 64K less RAM than TIMODE, so with MDOS 7.30 you actually have more free memory (when TIMODE is invoked) than with earlier OS iterations.  Native OS mode has less memory available but for most users, this won't be a noticeable concern.
One remaining "requirement" that I'd like to eliminate is the need for the extra 32K to run OS versions 2.50 or higher. The limitation comes from the SCSI buffer mechanism (and anything tied into it, like the Horizon and IDE) being hard-coded to SRAM.  If the extra 32K is not present, the OS should reserve a page in DRAM instead.  Changing the SRAM dependency isn't high on my list but is certainly kept in mind as other work is completed.
>1000   - RAMDISK
>1100   - Myarc HFDC
>1200   - SCSI
>1300   - (RS232 1/2)
>1400   - RAMDISK - Bootable
>1500   - (RS232 3/4) - but card needs modified.
>1600   - RAMDISK
>1700   - RAMDISK
>1800   - TIPI
>1900   - IDE
or
(If HFDC & FDC)
>1000   - Myarc HFDC
>1100   - FDC
Edited by dhe
need to update >1500
Just a stray thought, does the PFM or Memex have a CRU address that you need to be respectful of?
No
It's been a little while.
chkdsk was suppose to be like chkdsk for ms-dos.
What does chkdsk actually check for?
Has it been tested of IDE and TIPI also?
My personal opinion is the CHKDSK is fairly worthless, more so now that MEM reports the available memory. And a DIRectory provides more TI/Geneve relevant information anyway.  The /F option is only valid for floppy disk structures, so no IDE, SCSI,TIPI, HFDC, RamHD support now or in the future.
