TGB1718 Posted February 16, 2021 Share Posted February 16, 2021 I'm writing a device handler in cc65, it has a .c file and a .s file, I want to produce a listing of the build, I have '--listing centxe.lst' in the build call, but all it produces is a listing file of the .s file, not the .c file which is a bit daft as I already have the .s listing. Here's the call to build, any ideas as what I'm doing wrong, pretty sure I've seen the correct ouput before on another project. cl65 -t atari -O -Wl "-D__RESERVED_MEMORY__=1" --static-locals --listing centxe.lst centxe_main.c centxe_asm.s -o centxe.xex this is what I get:- ca65 V2.18 - Git beaa77d Main file : centxe_asm.s Current file: centxe_asm.s 000000r 1 ; .include "atari.inc" 000000r 1 HATABS=$31A 000000r 1 000000r 1 .export _sethatabs 000000r 1 .import _popen,_pclose,_pread,_pwrite,_pinit 000000r 1 .proc _sethatabs: near 000000r 1 .code 000000r 1 _sethatabs: 000000r 1 A0 00 INTABLE: LDY #0 000002r 1 B9 1A 03 FLOOP: LDA HATABS,Y 000005r 1 C9 50 CMP #'P' 000007r 1 F0 09 BEQ FOUND 000009r 1 C8 INY 00000Ar 1 C8 INY 00000Br 1 C8 INY 00000Cr 1 C0 22 CPY #34 00000Er 1 D0 F2 BNE FLOOP 000010r 1 38 SEC 000011r 1 60 RTS 000012r 1 A9 rr FOUND: LDA #<PTABLE 000014r 1 C8 INY 000015r 1 99 1A 03 STA HATABS,Y 000018r 1 A9 rr LDA #>PTABLE 00001Ar 1 C8 INY 00001Br 1 99 1A 03 STA HATABS,Y 00001Er 1 60 RTS 00001Fr 1 rr rr rr rr PTABLE: .WORD _popen,_pclose,_pread,_pwrite,_pinit,_pinit 000023r 1 rr rr rr rr 000027r 1 rr rr rr rr 00002Br 1 4C rr rr JMP _pinit 00002Er 1 .endproc 00002Er 1 Quote Link to comment Share on other sites More sharing options...
danwinslow Posted February 16, 2021 Share Posted February 16, 2021 You're using a much later version that I did, but just a -l on the cl65 command should do it. You have a -Wl, but I don't see just the -l. I am not familiar with --listing, they must have added that one (or I ignored it it for the shorter form). At any rate I did not have issues using mixed .c and .s files with output listings. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 16, 2021 Author Share Posted February 16, 2021 -l = --listing although on the cc65 web page it doesn't mention -l is the short form I changed the build script to cl65 -t atari -O "-D__RESERVED_MEMORY__=1" --static-locals -l centxe.lst centxe_main.c centxe_asm.s -o centxe.xex but still only the .s file is produced in the listing Interestingly I just tried with an older project that doesn't have a .s but does have 2 .c files and only one of them is produced in the listing and again, not the MAIN.C program file, really odd behavior. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 16, 2021 Author Share Posted February 16, 2021 Think I've solved it, it would appear only one file can be listed at a time and it looks like it's the last file on the command line, this now producing a listing for the .c file but not the .s cl65 -t atari -O "-D__RESERVED_MEMORY__=1" --static-locals -l centxe.lst -o centxe.xex centxe_asm.s centxe_main.c So it's a 'quirk/bug' in cc65 Quote Link to comment Share on other sites More sharing options...
sanny Posted February 16, 2021 Share Posted February 16, 2021 If you have more than one source file you can compile each source file separately (with optional different option) with the "-c" command line switch. Then link all the object files together. Example: $ cl65 -t atari -c -o file1.o file1.s $ cl65 -t atari -c -o file2.o file2.c $ cl65 -t atari -o prog.com file1.o file2.o 1 Quote Link to comment Share on other sites More sharing options...
sanny Posted February 16, 2021 Share Posted February 16, 2021 And, if an asm source file is OK instead of a "listing", use cc65. cc65 translates a file from C to assembler (it's called under the hood by cl65) 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 16, 2021 Author Share Posted February 16, 2021 (edited) Many thanks @sanny that makes much more sense to compile individually and link later. Update: Works a treat with the -c thanks again Edited February 16, 2021 by TGB1718 Update Quote Link to comment Share on other sites More sharing options...
