vitoco #1 Posted February 26 To define a sprite bitmap, it is required to do something like this: playerX: %00011000 %01100110 %11011011 %01100110 %00011000 end X is a number from 0 to 1 (standard kernel), 0 to 5 (multi sprite kernel) or 0 to 9 (DPC+ kernel), so you need to repeat the piece of code multiple times. If you want to do some animation with N frames, you have to repeat the code inside IF-THEN or ON-GOTO structures for every player frame. Is there a way in batari Basic to use the same N frames for all X players without having to rewrite X * N blocks when all players are moving at their own speed/direction/whatever? I guess I could manually assign the pointers to a given data block and also update the corresponding height if needed, but how? Is there a simple bB instruction/assignment or must I write an ASM block? Thanks... Quote Share this post Link to post Share on other sites
bogax #2 Posted February 26 This does something like what you want I think. Quote Share this post Link to post Share on other sites
vitoco #3 Posted February 26 Ok... the trick is to assign the following for each player when needed: playerXpointerlo = <BITMAP playerXpointerhi = >BITMAP playerXheight = HEIGHT Thanks! Quote Share this post Link to post Share on other sites
CapitanClassic #4 Posted February 26 As explained on the randomterrain website, you can also do (at least for DPC+) Or all sprites 1-9 (sprite0 is special) player2-3: %00111111 %00111110 %00000111 %00011111 %00111111 %11111110 %00111111 %00011111 %00000111 %00111110 %00111111 end Quote Share this post Link to post Share on other sites
+Karl G #5 Posted February 26 The data also needs to be defined in the last bank if it's a multi-bank project. If the data crosses a page boundary, then it may cause visual glitches. Quote Share this post Link to post Share on other sites
vitoco #6 Posted February 26 5 minutes ago, CapitanClassic said: As explained on the randomterrain website, you can also do (at least for DPC+) Or all sprites 1-9 (sprite0 is special) player2-3: %00111111 %00111110 %00000111 %00011111 %00111111 %11111110 %00111111 %00011111 %00000111 %00111110 %00111111 end I've read that, but it sets all the sprites in the range to the same frame at the same time... it is not what I want. 6 minutes ago, Karl G said: The data also needs to be defined in the last bank if it's a multi-bank project. If the data crosses a page boundary, then it may cause visual glitches. I was thinking about that. How can I force the data block to be defined in the last bank? I'm trying DPC+ kernel, BTW, so it will be banked 32K as I saw. Am I too ambitious? This is my 6th day of bB experiments. And I also want to include the QuadTari!!! 😬 1 Quote Share this post Link to post Share on other sites
bogax #7 Posted February 26 1 hour ago, vitoco said: Ok... the trick is to assign the following for each player when needed: playerXpointerlo = <BITMAP playerXpointerhi = >BITMAP playerXheight = HEIGHT Thanks! correct and as needed so eg in the example I pointed to the height never changes so it's set once A slight elucidation of Karl G's point, the table can span a page boundary but an individual sprite definition should not cross a page boundary If all the definitions are in a single page then you'll only need to change the lo byte 1 Quote Share this post Link to post Share on other sites
vitoco #8 Posted February 26 6 hours ago, bogax said: correct and as needed so eg in the example I pointed to the height never changes so it's set once A slight elucidation of Karl G's point, the table can span a page boundary but an individual sprite definition should not cross a page boundary If all the definitions are in a single page then you'll only need to change the lo byte Those are great hints. Thanks! Unfortunately, this does not seem to work for DPC+ kernel, except for player0. By reading DPCplusbB.h, it seems that a structure to manage each virtual player is copied into RAM portion of the ARM... this is completely new to me, so I can't figure out how this works. I'll try to find some examples... Quote Share this post Link to post Share on other sites
+Karl G #9 Posted February 26 6 hours ago, bogax said: A slight elucidation of Karl G's point, the table can span a page boundary but an individual sprite definition should not cross a page boundary If all the definitions are in a single page then you'll only need to change the lo byte That is true, but not what I meant. If an individual table crosses a page boundary in the middle, it will likely result in screen distortion this is what Freshbrood experienced with his Mortal Kombat work-in-progress. I have been brainstorming ways to get around this problem, such as perhaps having the ability to define a data statement in a way that forces it to be aligned properly at compile time. Alternate leg, perhaps a way could be devised to Define Sprites without assigning them, and allow them to be assigned to multiple player objects. Quote Share this post Link to post Share on other sites
+Karl G #10 Posted February 26 20 minutes ago, vitoco said: Those are great hints. Thanks! Unfortunately, this does not seem to work for DPC+ kernel, except for player0. By reading DPCplusbB.h, it seems that a structure to manage each virtual player is copied into RAM portion of the ARM... this is completely new to me, so I can't figure out how this works. I'll try to find some examples... Yeah, Sprites are stored differently internally with the DPC+ kernel. As CaptainClassic explain, though, you can Define multiple players at once to share Sprite data with that kerneln tthough. Unless I am misunderstanding you, in your example, you could set multiple players at once with one loop using DPC+. Quote Share this post Link to post Share on other sites
bogax #11 Posted February 26 1 hour ago, Karl G said: That is true, but not what I meant. If an individual table crosses a page boundary in the middle, it will likely result in screen distortion this is what Freshbrood experienced with his Mortal Kombat work-in-progress. I have been brainstorming ways to get around this problem, such as perhaps having the ability to define a data statement in a way that forces it to be aligned properly at compile time. Alternate leg, perhaps a way could be devised to Define Sprites without assigning them, and allow them to be assigned to multiple player objects. hmm You shouldn't need to align the table as a whole. Freshbrood didn't post his code so it's hard to know what's going on there. As far as aligning the table goes, what's wrong with the align directive you were using? bB sometimes includes some assembly to generate the correct padding. (15 is the length of the table -1) 2511 f730 - if (<*) > (<(*+15)) 2512 f730 - repeat ($100-<*) 2513 f730 - .byte 0 2514 f730 - repend 2515 f730 endif Quote Share this post Link to post Share on other sites
+Karl G #12 Posted February 26 27 minutes ago, bogax said: hmm You shouldn't need to align the table as a whole. Freshbrood didn't post his code so it's hard to know what's going on there. As far as aligning the table goes, what's wrong with the align directive you were using? bB sometimes includes some assembly to generate the correct padding. (15 is the length of the table -1) 2511 f730 - if (<*) > (<(*+15)) 2512 f730 - repeat ($100-<*) 2513 f730 - .byte 0 2514 f730 - repend 2515 f730 endif I looked at his code privately, and that's what I figured out. Yes, bB does align data such as player graphics to avoid cycle count discrepancies during the display kernel. Data from a normal data table does not automatically get aligned, however. Normally there is no need to align these kinds of data tables, as the extra cycles when reading from parts of the table that cross the page boundary have a minimal impact for non-kernel code. My conditional align directive is a solution for that. As it stands now, sharing sprite data requires going "under the hood" and setting pointers, making sure the data is defined in the right place, and making sure the data does not cross a page boundary, which are things a bB programmer doesn't usually need to worry about. Since I am trying to help with bB maintenance, I was brainstorming how sharing sprite data could be accomplished in a more user-friendly way via changes to the language itself. E.g. perhaps a "spritedata" keyword could be added that would automatically put data in the graphics bank, and ensure that the data doesn't cross page boundaries. What do you think? Quote Share this post Link to post Share on other sites
bogax #13 Posted February 26 50 minutes ago, Karl G said: As it stands now, sharing sprite data requires going "under the hood" and setting pointers, making sure the data is defined in the right place, and making sure the data does not cross a page boundary, which are things a bB programmer doesn't usually need to worry about. Since I am trying to help with bB maintenance, I was brainstorming how sharing sprite data could be accomplished in a more user-friendly way via changes to the language itself. E.g. perhaps a "spritedata" keyword could be added that would automatically put data in the graphics bank, and ensure that the data doesn't cross page boundaries. What do you think? heh heh I think they ought to just bite the bullet and learn enough about what's going on under the hood to know what they're doing Its not THAT complicated. I think it would be useful to have some lowest-common-denominator way of choosing among multiple sprite definitions for animations and such built in to bB Something more stream-lined than the usual clumsy, wasteful string of if-thens Given the variety of ways it might be done and the possible tradeoffs it might be better to have a utility that generated bB or assembly and could be more general (in addition to whatever got included in bB) Besides, if bB is going to be augmented I'd rather see the effort go in to other things. Quote Share this post Link to post Share on other sites
