iridude Posted April 3, 2021 Share Posted April 3, 2021 Curious would a heat gun work with older consoles to reflow and desolder? What solder gun you guys recommend? Reflow/solder station? Thanks Quote Link to comment Share on other sites More sharing options...
rietveld Posted April 5, 2021 Share Posted April 5, 2021 On 4/3/2021 at 3:42 PM, iridude said: Curious would a heat gun work with older consoles to reflow and desolder? What solder gun you guys recommend? Reflow/solder station? Thanks I just used a cheap $10 soldering iron to reflow the joystick ports on my Gemini Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 5, 2021 Share Posted April 5, 2021 Depends on what you are planning to do. A standard solder sucker will work for most projects. But on the +5 RAM I would advise a good de-soldering gun. I have an older Hakko FR-300 myself that I've used for several years now. But if you don't have access, I've heard my local shop has success using their hot air rework station to remove components from the bottom side of the board. Can also just cut the components out with flush cutters, and then use a standard soldering iron to remove the leads from the vias after. Quote Link to comment Share on other sites More sharing options...
