11 hours ago, MasterMotorola said:
Mike, yes Motorola made a 50Mhz 68882 FPU.  I was considering getting one until I found out the CaTTamaran overclocks the FPU as well so there would really be no speed boost.
The problem I’m having is my FPU is not stable over clocked.  I have even tried a 40 mhz version, but no luck. I would love to find a 50 mhz version to fix this problem. Otherwise I will have to make a small mod and run my FPU at 32 mhz.
Right with ya. I've got a 40mhz 68882 in my Pak 68/3 equipped STacy and in
some of the benchmarking threads in other forums I was requested to run
Nembench because of some odd results I got.
Can't. It fails, so it seems I have a faulty 68882.  :(
(even though Gembench, and all the other software runs fine with no crashes. This
includes software that uses an FPU. Go figure)
More than likely it is not faulty, we are just trying to make it do something it was never designed to do.
Be nice to think that but the testing software they asked me to use (NEMBENCH, by Douglas Little) works
fine on other people's setups, including Pak boards... :(
NEMBENCH is not benchmarking software per se - it actually tests the 68882/1, if I my understanding of it is
correct.... (of course, I get things wrong all the time)
NEMBENCH looks like it’s just a benchmark program from a quick search of the forums. Can you step the speed of your setup down and test? I’m sure it’s a speed issue with the FPU. While there are plenty of people who run there FPU at 48mhz, there are many who can’t. My 33 mhz and 40 mhz FPUs both run for hours at 32 mhz. Neither will run at all at 48mhz.
My bad...I've been running so many bench marking tests lately that I
got NEMBENCH confused with FPUTEST.
FPUTEST is the one that fails on my setup. It's supposed to test the
FPU, not benchmark it.
Sorry about the confusion.  :(
Unfortunately, with the Pak 68/3 boards, you are supposed to run the CPU and FPU at the same speeds.
So I'm running the 68030 at 40mhz....you get the picture.
With the Pak board, you change the CPU, FPU and oscillators, matching them all up to the same mhz. That's
what's recommended.
When/if I take my STacy apart I can play around with different speeds. Taking a STacy apart is not a light
undertaking.   :)
I have only seen 50MHz in PGA. Max in PLCC I have seen is 40MHz. I don't think 50MHz was made in PLCC package.
I kinda figured that...
undertaking.   :)
As I well know...
send me FPUTEST please. May as well test mine.
Posted (edited)
Interesting FPU conversation.
Does anyone knows if this will work in my Atari ST/e ( ICD AdSpeed STE 16MHz ).
Can't find online manual for ICD AdSpeed STE 😟
Edited by Chri O.
Probably yes. The 68882 is asynchronous and can have a different speed then the 68000. The AdSpeed for STe is missing the oscillator so you also need to fit that. So you could probably have 20MHz oscillator in there for the 68882. Or 32MHz or 50MHz if you have faster 68882.
Hmm, what are you using to access the 68882?
In my case, the Pak board has an option for a 68881/2.
This ZIP should contain what you need for the AdSpeed:
ADSPEED ST.ZIP
8 hours ago, mdivancic said:
As I well know...
Sure, hope yours is fine.   :)
fputest.zip
If I haven't asked this before, is there a list of programs for the ST/TT/Falcon that actually supports the 68881/2?
