Jimd0586 Posted May 25, 2021 Share Posted May 25, 2021 So I purchased a PCB for street fighter II on ebay and low and behold it was bootlegged. That was my fault that I didn't read the fine print. It is an "MSTREET-6" board if I am reading it correctly. My JAMMA harness doesn't look like it will fit as there is a notch in my harness and the pinout on the board has no space for the notch to fit into. And how do I connect the kick harness? Here is a picture of the board: https://ibb.co/z7SQHXD Any suggestions? Quote Link to comment Share on other sites More sharing options...
number six Posted May 27, 2021 Share Posted May 27, 2021 Yeah that's a pretty obvious bootleg. You'll need to figure out the pinout for it. Chances are they used the edge connector for the kick buttons, you see this a lot with bootlegs or newer board like the Pandoras. Either way you'd need to make an adapter to get it to work in a normal Jamma harness. Without knowing the pinouts its a bad idea to just try to plug it in or somehow make it fit as well. Quote Link to comment Share on other sites More sharing options...
