MausR Posted July 2, 2021 Share Posted July 2, 2021 Since over a week i have problems to get my Side3 running with SDX and register the SD. To understand the following hardware is used: 800XL with 320k megaram expansion, Sophia2, Side3 Booting without SD-Card: Booting with SD-Card inserted: Using the Sideloader an SD-Card all works fine an i can start ATR files till 180kb. But if i'm using my spare 800XL without any upgrades SDX boot up and recognise the SD-Card every time. For me it look like that the PSU is weak. (apologize for the wrong term) Any suggestions? Quote Link to comment Share on other sites More sharing options...
candle Posted July 2, 2021 Share Posted July 2, 2021 so if you're using unexpanded 800xl, sdx boot to the prompt, whereas if you use expanded 800xl, cartridge boots only if card is removed, and when inserted it hangs before displaying a prompt? Quote Link to comment Share on other sites More sharing options...
MausR Posted July 2, 2021 Author Share Posted July 2, 2021 thats right, only 2 times it startet sdx and recognized the SD-Card but normaly it hang up. i have tried i today 50 - 60 times an only 1 time it boots up right. that's the last try before reading your message @candle and that's how it looks on the unexpandet one. The Side3 is working fine. Quote Link to comment Share on other sites More sharing options...
candle Posted July 2, 2021 Share Posted July 2, 2021 have you tried with diffrent SD cards? Can you disable that extended memory? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 2, 2021 Share Posted July 2, 2021 (edited) Also, check ya A8's power supply. I couldn't get Side3 to work at all, then I bought a 5v 3a USB power cable for my XE. Worked. See here: I read sometimes the sdcard doesn't read if not enough juice going into the Atari overall. If you have an old school original Atari psu like I did (see post) it doesn't appear to have enough amps. Add to that any other drain on the power (Eg U1MB) and it all contributes. Edited July 2, 2021 by Beeblebrox 2 Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted July 2, 2021 Share Posted July 2, 2021 Update your Side3, that's the main thing. I just checked on almost the same config as yours (600XL upgraded to 64K + RAM320XL + Side3) and everything works fine. 2 Quote Link to comment Share on other sites More sharing options...
MausR Posted July 2, 2021 Author Share Posted July 2, 2021 thanks for all feedback. i orders some sd's and a new 3A PSU and on top SIO2PC to mount the update, but it will take a few days to receive the goods. Quote Link to comment Share on other sites More sharing options...
Level42 Posted July 2, 2021 Share Posted July 2, 2021 Use an original PSU, I have zero problems with loads of upgrades inside my 600XL. Quote Link to comment Share on other sites More sharing options...
Tillek Posted July 3, 2021 Share Posted July 3, 2021 Actually, not all of the original Atari PSU models pumped out the same amps. Some were beefier than others. You might just have one of the better ones and the OP, one of the lower rated ones. 2 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 3, 2021 Share Posted July 3, 2021 (edited) Before I figured it out for my personal A8 setup issues, I'd found that my SIDE3 cart worked on my 2 x other XE A8s with the same stock Atari brick (5v 7.4va (1.5a)) powering them with no issues, but NOT on my 65XE (even before it was upgraded with U1MB). Then with the U1MB installed and it still not working the only thing that fixed it in my case was getting the USB power cable which had the extra amps (3a). Call it a quirk of this particular 65XE (even before I added U1MB), or perhaps it has slightly different electronic componentry. (Plus of course we are talking of decades old tech). Point is I guess not all A8s are created equally. The USB power cable cost me less than a tenner and as soon as I powered up the 65XE it worked straight away. I then spent a few hours pretending I was 25+years younger saving countless of my lil Brundle buddies!! I love SIDE3 and my new 1MB XE Edited July 3, 2021 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Sugarland Posted July 3, 2021 Share Posted July 3, 2021 1 hour ago, Beeblebrox said: Before I figured it out for my personal A8 setup issues, I'd found that my SIDE3 cart worked on my 2 x other XE A8s with the same stock Atari brick (5v 7.4va (1.5a)) powering them with no issues, but NOT on my 65XE (even before it was upgraded with U1MB). Then with the U1MB installed and it still not working the only thing that fixed it in my case was getting the USB power cable which had the extra amps (3a). Call it a quirk of this particular 65XE (even before I added U1MB), or perhaps it has slightly different electronic componentry. (Plus of course we are talking of decades old tech). Point is I guess not all A8s are created equally. The USB power cable cost me less than a tenner and as soon as I powered up the 65XE it worked straight away. I then spent a few hours pretending I was 25+years younger saving countless of my lil Brundle buddies!! I love SIDE3 and my new 1MB XE Maybe it's a failing capacitor or the LS timing chip in the 65XE? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 3, 2021 Share Posted July 3, 2021 1 hour ago, Sugarland said: Maybe it's a failing capacitor or the LS timing chip in the 65XE? @Sugarland Hi. thanks for the suggestion. Ironically as detailed just this minute below, there have been some new rather depressing developments overnight with my 65XE U1BM upgraded A8. (Which may well be now as a result of perhaps what you suggest for this particualr A8 of mine): Although as yet it's not confirmed for sure as the issue, happily at least I've a replacement 74F08 chip on the way. More info in the above post if ya interested, (so I don't hijack this thread). cheers Quote Link to comment Share on other sites More sharing options...
MausR Posted July 4, 2021 Author Share Posted July 4, 2021 @candle the megaram XL/XE version 1 from K.Peters are soldered all over the mainboard and I'am not able to disable this thing. New SD-Cards arrived and thats don't chnage anything. I had a one time luck for two of the three cards and had a chance to run FDISK and put patitions on ist. The Side3 loader. If the other things don't help i have to look for someone near by with the right knowledge and equipment to sort the problems out. Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted July 4, 2021 Share Posted July 4, 2021 Afaik, the Megaram 1, 2 and 3 do have problems regarding refresh. There were one or two articles in the Abbuc magazine on how to fix this problem. You can find a german description/fix on B. Pahl's webpage. Hopefully this helps. 1 Quote Link to comment Share on other sites More sharing options...
MausR Posted July 9, 2021 Author Share Posted July 9, 2021 On 7/4/2021 at 11:15 PM, CharlieChaplin said: Afaik, the Megaram 1, 2 and 3 do have problems regarding refresh. There were one or two articles in the Abbuc magazine on how to fix this problem. You can find a german description/fix on B. Pahl's webpage. Hopefully this helps. I think that's more than a possibility. After flashing SDX of the Side 3 to the latest Version and using a new PSU, it's still the same result. Quote Link to comment Share on other sites More sharing options...
Mazzspeed Posted July 10, 2021 Share Posted July 10, 2021 (edited) EDIT: Sorry, I see my advice has been tried already. Post removed. Edited July 10, 2021 by Mazzspeed Quote Link to comment Share on other sites More sharing options...
