jasonbar Posted July 19, 2021 Share Posted July 19, 2021 https://www.ebay.com/itm/114897374509 Lot: Nintendo 64-Modded for SCART RGB + Everdrive Flash Cart 4 Controllers, 2 Memory Cards, All Cables-ALL TESTED GOOD NINTENDO 64 CONTROL DECK. US MODEL NUS-001(USA) Clean, with minor normal scratches & scuffs from handling & storage. Mod to use the existing Nintendo AV out port for SCART RGB--RGB looks fantastic. EVERDRIVE FLASH CART-STONGE AGE GAMER DELUXE EDITION By Krikzz. Works great. One of the first purchases: serial number 0045, purchased August 2011. Can hold the entire N64 library on a 32 GB SD Card. Housed properly in a cartridge shell, with a classic-style label. A current-version EverDrive alone costs $100+ new online! (see Amazon, Stone Age Gamer, or EverDrive.me). Rental-style case with cover. Instruction manual. 2 stickers. 2 vouchers for free firmware upgrades. "Voucher is transferable. Does not expire." 32GB SD CARD RESOLD BY STONE AGE GAMER Works with Everdrive. More than enough to hold the entire system library, & then some (add your own software--I'll put a few public domain demos on the card to get you started). Formatted correctly to work w/ Everdrive. 4 CONTROLLERS Very good condition. All functions tested good: all buttons, analog stick self-centers. AC ADAPTER POWER SUPPLY Nintendo Model NUS-002(USA). In: 120V 26W 60Hz, Out: 3.3VDC, 2.27A & 12VDC 0.8A. Original power supply, no hum, no issues. 2 MEMORY CARDS a) Performance Memory Card Plus. Model no. P-375A. 4 banks, selectable by switch. I put in a brand new CR2032 battery for this auction. b) Performance Memory Card. Model no. P-302. I checked the CR2032 battery for this auction--it's still over 3V, so it should be good for a while. RGB SCART + AUDIO CABLE Professional quality cable, purchased from a cable shop. Provides exquisite video & audio for your RGB gaming monitor! Thank you, -Jason 1 Quote Link to comment Share on other sites More sharing options...
ClassicGMR Posted July 19, 2021 Share Posted July 19, 2021 Quote Link to comment Share on other sites More sharing options...
