SS Posted October 23, 2021 Share Posted October 23, 2021 I am likely going to put a SOPHIA board into my 600XL project so I will also need to add an audio jack to it. The last time I did this, I left the RF modulator intact and simply attached a wire to the audio feed leading to it. This method worked but seems a rather sloppy solution so I am looking for a better way to get an audio connection this time around. Any help would again be greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted October 23, 2021 Share Posted October 23, 2021 (edited) I just pull mine from the monitor port. Of course, I removed the channel selector switch and added the monitor port when I upgraded the video with a UAV. There were only a couple of wires I had to solder. I can't recall if audio was being pulled from somewhere else on the board, or if it was just coming from the monitor port traces/pads that are still on the motherboard underneath the channel selector switch. You do realize that everything for the monitor port, except for the actual monitor port; traces, pads, everything, are actually still on the NTSC 600XL motherboard, underneath the channel selector switch, right? I'll try to check my documentation later and confirm. EDIT: I found this. Hopefully, Marlin won't mind me posting it here for your reference. If you don't like that spot for some reason, I guess you could follow that trace back to another spot or component further back and patch it in there. Edited October 23, 2021 by bfollowell 2 Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted October 23, 2021 Share Posted October 23, 2021 1 hour ago, bfollowell said: I just pull mine from the monitor port. Of course, I removed the channel selector switch and added the monitor port when I upgraded the video with a UAV. There were only a couple of wires I had to solder. I can't recall if audio was being pulled from somewhere else on the board, or if it was just coming from the monitor port traces/pads that are still on the motherboard underneath the channel selector switch. You do realize that everything for the monitor port, except for the actual monitor port; traces, pads, everything, are actually still on the NTSC 600XL motherboard, underneath the channel selector switch, right? I'll try to check my documentation later and confirm. EDIT: I found this. Hopefully, Marlin won't mind me posting it here for your reference. If you don't like that spot for some reason, I guess you could follow that trace back to another spot or component further back and patch it in there. Hi @bfollowell, You are correct. The trace for the 5 pin DIN connector still has the audio on the trace. When I did my UAV upgrade and installed the DIN connector, I did not have to run any lines to connect the audio. It was just there on the trace. I have attached a photo of my 600XL with UAV installed with the 5 DIN connector installed for video and audio out. I had removed the RF modulator. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted October 23, 2021 Share Posted October 23, 2021 2 minutes ago, scorpio_ny said: Hi @bfollowell, You are correct. The trace for the 5 pin DIN connector still has the audio on the trace. When I did my UAV upgrade and installed the DIN connector, I did not have to run any lines to connect the audio. It was just there on the trace. I have attached a photo of my 600XL with UAV installed with the 5 DIN connector installed for video and audio out. I had removed the RF modulator. I wanted to keep mine as close to stock as I could, so I soldered my socket on top of the CD4050 and only removed the channel switch, but not the modulator. That way the RF modulator still works, albeit only on one channel; 3 I think. It's really only an academic consideration, not a practical one, as I can't imagine I'll ever really use it again. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 23, 2021 Share Posted October 23, 2021 keeping the 4050 was a good choice and has added benefits... as described by myself and others such as tf_hh Quote Link to comment Share on other sites More sharing options...
SS Posted October 23, 2021 Author Share Posted October 23, 2021 This is all great information for me to tuck away. I have a few 600XLs in spare and my next project after this one will be adding a DIN connector and UAV to one of them. Thanks everyone! Quote Link to comment Share on other sites More sharing options...
