I understand, but this behavior is inconsistent for me.
For this I need to remember the type/value I put in for repeat to know how this gonna be behave.
No, it just counts the number of times you tell it. It's exactly the same as in Logo, which was carefully designed sixty years ago to teach kids programming.
You think it should be more complicated because you are used to that.
ok... I made a fool of myself, correcting the code accidentally deleted the variable and I did not notice it - hence further unnecessary discussion.
1000 - var behave exactly the same as 10 - var.
apologize.
Edited by zbyti
To clarify, I was sure the code looks like this:
count: 1000
repeat count [write/line count: 1000 - count]
write/line "dupa end"
but it looked like this:
count: 1000
repeat count [write/line 1000 - count]
the first produces 0 and 1000 alternately (which I don't understand), and the second of course 0.
lack of readability from my side ;)
Edited by zbyti
ping atari8.metaproject.frl
ping: atari8.metaproject.frl: Temporary failure in name resolution
this makes it difficult to play with. I wanted to write something more in Meta.
unsafe!!! constant reference volatile byte! [
  RND= ~D20A
forever [
  either RND < ~80 [write "/"] [write "\\"]
write "workaround"
program.xex
without last line I have an error:
out.c:26: Error: Expression expected
out.c:26: Error: Illegal function call
out.c:31: Error: Incomplete type 'void'
out.c:32: Warning: Parameter 'arguments' is never used
4 errors and 1 warnings generated.
switch, and, or, xor - not implemented yet?
and again:
./compile test.meta
Compiling file test.meta
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: atari8.metaproject.frl
Result is in file program.xex
it's not fun...
Edited by zbyti
4 minutes ago, Kaj de Vos said:
Looks like you need a better DNS provider. Try 1.1.1.1 or Google.
I don't think so. I used 8.8.8.8 and 1.1.1.1.
@Kaj de Vos I'll back to testing Meta if you clearly let us know what part of REBOL is implemented. For now I used http://rigaux.org/language-study/syntax-across-languages-per-language/Rebol.html
It's time consuming - guessing whats works what not. Online compiler spoil fun too.
  RTCLOK3= ~14
  STICK0= ~278
forever [
  tmp: RTCLOK3 + 4
  while tmp > RTCLOK3 []
    if STICK0 = 14 [write/line "UP"]
    if STICK0 = 13 [write/line "DOWN"]
    if STICK0 = 7 [write/line "RIGHT"]
    if STICK0 = 11 [write/line "LEFT"]
write "workaround"
program.xex
without not implemented switch + workaround
7 minutes ago, Kaj de Vos said:
Nested EITHER is better.
simply I just deleted "switch" and added "if" to the rest - even indentations remained :D
  • Haha 1
foo: byte![1 2 3]
write "..."
 ./compile test.meta
100    54  100    24  100    30     62     77 --:--:-- --:--:-- --:--:--   139
word: 1
word: 2
word: 3
Sure.
Take your time and make proper documentation, implement missing things and improve parser.
In current state I can't image who else wants to take a ride withe Meta ;) I'm quit now too.
d:\Projekty\Meta>dir /b
compile.ape
curl.exe
libcurl.dll
test.meta
d:\Projekty\Meta>compile.ape test.meta
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
d:\Projekty\Meta>dir /b program.xex
File Not Found
I tried to use the compile.ape with curl.exe to compile a sample program, however with "Result is in file program.xex" there is no program.xex in the current directory. Any hints?
16 hours ago, Kaj de Vos said:
Again, there isn't one yet. It takes a lot of time to write documentation. It's great if you want to try Meta already, but then you have to make do with the few examples I have published so far and the REBOL documentation I have selected. It's really useful to work through that to learn the basics.
I agree that writing documentation is time consuming, but documentation for a new language is a must have. Maybe less time consuming would be pointing the differences from REBOL? Now for the ones that try to use the language it is a guessing game.
Here is the best REBOL guide that I found so far:
https://www.cis.upenn.edu/~matuszek/Concise Guides/Concise Rebol.html
Edited by ilmenit
