TGB1718 Posted December 4, 2021 Share Posted December 4, 2021 I've been having problems getting Timer 2 working even though I've used it many times in the past, essentially it crashes the machine soon after it's initialized. I did some testing and in spite of the frustration trying to figure out what's wrong (I thought it was a bug in Altirra), but did a similar thing on a stock 800XL with SIDE3, but only at $A000. Remaining testing done in Altirra:- I noticed if a test routine was assembled in Page 6 it worked fine ??? I change the address to $4000 and still it was crashing, my original routine sat between $A000 and $AD00 My system for testing is a 130XE with U1M and SIDE3. I compiled a test routine to run at all $2000,$3000 etc up to $B000 All tests worked except the ones at $4000,$5000,$6000,$7000 and $A000 I set the system to Stock 800XL with SIDE3 and the only failure was at $A000 ? So it looks like Timer2 is being affected by probably 2 things. As $A000 is affected I think SDX is doing something (I had to use the 'X' command to run the code although $B000 was ok) and/or the 16K memory window for the switched RAM blocks is having some effect, I thought it may be U1M but again SDX uses RAM through this window, so probably it's SDX again. Anyone seen anything like this before. This is the simple test program in MAC/65 10 .INCLUDE #D:HEADER.M65 20 *= $3000 30 LDA # <VBR 40 STA CDTMA2 50 LDA # >VBR 60 STA CDTMA2+1 70 RESET LDA #0 80 STA CDTMV2+1 90 LDA #30 0100 STA CDTMV2 0110 RTS 0120 VBR INC NUM 0130 CLV 0140 BVC RESET 0150 NUM .BYTE 0 0160 .OPT NO LIST Quote Link to comment Share on other sites More sharing options...
drac030 Posted December 4, 2021 Share Posted December 4, 2021 16 minutes ago, TGB1718 said: As $A000 is affected I think SDX is doing something $A000-$BFFF is normally occupied by the SDX cartridge. If you want RAM there, use X command (as you did). 17 minutes ago, TGB1718 said: the 16K memory window for the switched RAM blocks is having some effect, I thought it may be U1M but again SDX uses RAM through this window Yes, "USE BANKED" configuration, as you said, uses the Ext RAM, doing the memory banking at $4000-$7FFF. Any I/O call will result in the memory being banked, so if you put your interrupt routine there, expect a crash. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted December 4, 2021 Author Share Posted December 4, 2021 8 minutes ago, drac030 said: $A000-$BFFF is normally occupied by the SDX cartridge. If you want RAM there, use X command (as you did). What was confusing me is calling @$A000 crashes, but $B000 doesn't and obviously I have to use the 'X' command or it won't run anyway. Thanks also for your explanation about the banked memory, I guessed as much, just annoyed at myself for not spotting the issue was the banked ram are earlier. Quote Link to comment Share on other sites More sharing options...
