walldog1 Posted June 5, 2022 Share Posted June 5, 2022 (edited) The first pictured item sold 06/21/22, but don't worry, I have many more (45 to be exact) that are rebuilt, partially rebuilt, or still need rebuilding. They all get the same kind of attention as the one below. Many will be around the $145 price depending on console condition and extra parts needed than average rebuild. I will also have a couple separate listings soon with like new controllers, one which will be modded with the "orange peel" RGB Mod Kit. I was planning on using the 8 pin mini Din connector, but if you are interested and want the 9 Pin for Sega-Genesis II cable connection, message me. This is the listing description for #50 INTV 2609 & Pictures of it: I will include a game of your choice! I bought this "for parts" console. It was sold in Australia originally. I then disassembled, cleaned, repaired, & tested. I installed a fan to blow through holes on the side of the Logic Board to help keep the 3 heat sinked IC Chips to stay cooler as they are very scarce to find and prone to failure. They are becoming rare and hard to find parts these days. It also blows air over the LB to the DC Power Supply to help keep that cool as well. Blows 10 CFM of air and does a good job! Rated 30 decibels, so as loud as a tower computer is. Look at Pics! The Hand Controllers were fully disassembled and cleaned, Wire Harnesses tested for continuity on all wires individually, and tri-fold tracing also measured good. In fact, these Mylar Tri-folds are in excellent condition, close to like new! Look at picture! The Button Spring is lengthened for better response & a dab of silicone to stop plastic wear under disc. I disassembled the Logic Board case which someone else had mangled pretty good. I was able to restore it as seen in the pictures. The PCB was very pristine in cleanliness inside, as well as all electronic components. It had a bad 9600 IC Chip which was replaced. I removed Transistor Q1 & Q2, and they tested bad so I replaced with new ones. 10qF electrolytic capacitors which I also pulled and tested and replaced the two bad ones (C40 & C26) and 3rd as well. I also needed to repair over 150 solder joints as age was not kind to them. I then timed crystal clock to 3.579545 MHz with my Oscilloscope which was WAY OFF! Probably another part of the problem all along, along with the weak DC Power Supply. I ALSO added another ground on the 5.65VDC 2-PIN Connector, as is my policy when reworking any Logic Board! Using only the 1 ground on the flimsy ribbon connector is quite a load of work for that single circuit. That connection on Logic Board usually shows signs of over heating on back side of logic board. I always scrape away the "crud" and beef up the solder joint for ground on both sides of Logic Board where Ribbon Wire connects. Ribbon wire is in very good condition as well. Look at pictures. DC Power Supply Board test points did not test good, and all electrolytic capacitors needed replacement as they were weak. I used the more expensive 8000 hr rated capacitors rather than the 2000 hrs that are less costly. Inflation has really increased their prices, sorry. I also installed a Flame Proof 5 Watt resistor instead of 3 Watt stock. This one will never burn out! Then all power supply check points both AC & DC tested very good after repairs. AC Transformer stays cool, even overnight while plugged in. It is always best though to unplug when not using console. Reassembled and tested several different games & played for an hour or longer at a time to show any potential future problems. Operates great and hopefully for years to come and has a very great picture! I strive to give every unit I rebuild my best effort and an eye for details that I can. I can also rebuild your INTV 2609's or add a Mod Kit to one of my 44 consoles or your own. I can also add a fan (I have quiet 5CFM Fans also) to help keep those rare IC Chips in the Logic Board cooler and hopefully last longer. ACCEPTABLE VOLTAGE RANGE ACTUAL FOR THIS UNIT #50 TP1: Ground 0.00 VDC TP2: (4.85 to 5.15 VDC) 4.97 VDC TP3: (11.64 to 12.36 VDC) 12.02 VDC TP4: Unregulated 16 VDC (16 to 25 VDC) 22.9 VDC TP5: (-1.95 to -2.25 VDC) -2.19 VDC TP6: Unregulated 12 VDC (11.5 to 12.5 VDC) 11.51 VDC TP6 Loaded: (5.45 to 5.85 VDC) 5.75 VDC AC Pin 1 & 3: (7.6 to 9.4 VAC) 9.21 VAC AC Pin 2 & 3: (7.6 to 9.4 VAC) 9.22 VAC AC Pin 4 & 5: (15.3 to 18.7 VAC) 17.80 VAC Edited July 7, 2022 by walldog1 Addition update 2 Quote Link to comment Share on other sites More sharing options...
Humblejack Posted June 5, 2022 Share Posted June 5, 2022 Great to see you found a place to sell. They look great and I really like the detail you get into describing the unit and it's voltages. Good luck I hope you sell a bunch. Quote Link to comment Share on other sites More sharing options...
walldog1 Posted June 5, 2022 Author Share Posted June 5, 2022 (edited) Thanks Jack, not only for this comment but for all we have helped each other out with regarding INTV's! Edited June 5, 2022 by walldog1 Quote Link to comment Share on other sites More sharing options...
+nurmix Posted June 6, 2022 Share Posted June 6, 2022 Nice work! Clearly you do a thorough job refurbishing these consoles. 1 Quote Link to comment Share on other sites More sharing options...
poppalarge Posted June 25, 2022 Share Posted June 25, 2022 I bought a refurbished INTV from @walldog1 and two days later it was on my doorstep safe and sound. He took great care in packaging the system and I can't wait to fire it up. Anyone looking for an Intellivision that has a lot of detailed work and care put into it by a professional should look no further. 1 Quote Link to comment Share on other sites More sharing options...
