Sign in to follow this
Happy_Dude
Disassembling 8k rom ?
Distella only does 2 and 4k roms.
How can I go about disassembling an 8k rom ?
I have described that in the Programming forum some time ago.
you wouldn't have a Centipede disassembly by any chance ? :)
Though I have collected more than 50 DiStella configuration files, Centipede is not one of them. Sorry.
when I figure it out I'll send it to you.
Here you go. There are most definately some tags that haven't been detected, and all the vectors need labelling...
Label LDF10 holds the offsets (low bytes) for the digits' bitmap start addresses...you can save half of the memory devoted to the bitmaps by reorganizing them like this:
;erase all data between LDF10 to LDF70, and add this:
LDF10:
;digit look up table...
      .byte <Digit0
      .byte <Digit1
      .byte <Digit2
      .byte <Digit3
      .byte <Digit4
      .byte <Digit5
      .byte <Digit6
      .byte <Digit7
      .byte <Digit8
      .byte <Digit9
      .byte <DigitSpace
      .byte <DigitXtra
;bitmaps
Digit1:
      .byte $0E; |    XXX | $DF1C
Digit7:
      .byte $0E; |    XXX | $DF1D
      .byte $0E; |    XXX | $DF1E
Digit4:
      .byte $0E; |    XXX | $DF1F
Digit9:
      .byte $0E; |    XXX | $DF20
      .byte $0E; |    XXX | $DF21
      .byte $0E; |    XXX | $DF22
Digit8:
      .byte $FE; |XXXXXXX | $DF23
      .byte $CE; |XX  XXX | $DF24
      .byte $CE; |XX  XXX | $DF25
Digit6:
      .byte $FE; |XXXXXXX | $DF26
      .byte $CE; |XX  XXX | $DF27
      .byte $CE; |XX  XXX | $DF28
Digit2:
      .byte $FE; |XXXXXXX | $DF29
      .byte $C0; |XX      | $DF2A
      .byte $C0; |XX      | $DF2B
Digit3:
      .byte $FE; |XXXXXXX | $DF2C
      .byte $0E; |    XXX | $DF2D
      .byte $0E; |    XXX | $DF2E
Digit5:
      .byte $FE; |XXXXXXX | $DF2F
      .byte $0E; |    XXX | $DF30
      .byte $0E; |    XXX | $DF31
      .byte $FE; |XXXXXXX | $DF32
      .byte $C0; |XX      | $DF33
      .byte $C0; |XX      | $DF34
Digit0:
      .byte $FE; |XXXXXXX | $DF35
      .byte $CE; |XX  XXX | $DF36
      .byte $CE; |XX  XXX | $DF37
      .byte $CE; |XX  XXX | $DF38
      .byte $CE; |XX  XXX | $DF39
      .byte $CE; |XX  XXX | $DF3A
      .byte $FE; |XXXXXXX | $DF3B
DigitSpace:
      .byte $00; |        | $DF3C
      .byte $00; |        | $DF3D
      .byte $00; |        | $DF3E
      .byte $00; |        | $DF3F
      .byte $00; |        | $DF40
      .byte $00; |        | $DF41
      .byte $00; |        | $DF42
DigitXtra:
      .byte $38; |  XXX   | $DF43
      .byte $6C; | XX XX  | $DF44
      .byte $6C; | XX XX  | $DF45
      .byte $7C; | XXXXX  | $DF46
      .byte $54; | X X X  | $DF47
      .byte $BA; |X XXX X | $DF48
      .byte $C6; |XX   XX | $DF49
      ORG $DF70
They will look different, but it will leave $DF4A to $DF6F free
