raster/c.p.u. Posted October 4, 2004 Share Posted October 4, 2004 Hot news 4.10.2004 ... New RMT 1.17 tracker. http://www.infos.cz/raster/atari/rmt/rmt.htm Changes in RMT 1.17 ------------------- - Menu Track: * Load and paste to actual track. * Save actual track as... * Clear all duplicated tracks, adjust song. (Note: This function is also included in Song - All size optimizations.) - New block effect/tool (menu Block - Effect/tools or Ctrl+F or toolbar button "FX") function: "Modify notes, instruments and volumes". - Function "Song - Prepare song line with unused empty tracks (Ctrl+P)" was changed to "Song - Insert new line with unused empty tracks (Ctrl+P)" and now it insert this new songline into actual song line positions, not to line below. - Function "Song - Prepare duplicated song line (Ctrl+O)" was changed to "Song - Insert copy or clone of song line(s) (Ctrl+O)". and now it shows new copy/clone dialog for setting of parameters for this very helpful function. - Menu Song: * Put new empty unused track to actual song position (Ctrl+N). - "File - Export as XEX Atari executable msx" there is possible to: * define 4+1 lines now. 5th line is showed instead of 4th line if Atari SHIFT key is pressed. * define color of rasterline meter. - "File - Export as SAP file" there is possible to define hexadecimal song line numbers for more SAP module subsongs. Initial values are prepared by automatic subsong-detection algorithm, but you can change it at pleasure. - Added "*.tm8" extension in Import TMC open file dialog. - New option in Config dialog (menu View - Configuration): * F1-F8 keyboard layout: - RMT original keyboard layout. - Layout 2: F1=track edit,F2=instrument edit,F3=info edit,F4=song edit F5=Play,F6=Play from start,Ctrl+F7=Play tracks,F7=Replay tracks,F8=Stop (This layout is for F5-F8 keys identical with some other renowned module tracker programs.) Accessories - Atari RMT player RMTPL104.XEX (new version 1.04) is in "player" directory. (There is short description in RMTPL104.TXT file.) New songs - Song "hexxagon.rmt" (Hexxagon music & sfx, raster/c.p.u., 2003) Song "basix.rmt" (Basix, by raster/c.p.u. 2004) Song "gemx.rmt" (Gem'x song, Atari version by raster/c.p.u. 2004) in "songs" directory. (SAP file "hexxagon.sap" with 6 subsongs is in "exports/sap" directory.) (SAP file "basix.sap" with 9 subsongs is in "exports/sap" directory.) Bug fixes - Revision of keyboard control. NumLock mode is turned off all the time when tracker main window is active, so that key combinations Shift+NumBlockKeys are working as well as state of right Shift key can be correctly detected now. - Internal improvement of TMC import algorithm (better recognition of identical tracks arised from other tracks by song shift parameter). - If tracker window isn't active, MIDI events on channel 0 are ignored. - Other small corrections and bugfixes. Enjoy it! Greetings, raster/c.p.u. Quote Link to comment Share on other sites More sharing options...
Tezz Posted October 4, 2004 Share Posted October 4, 2004 Great stuff Raster. Look forward to checking this out tonight!! Quote Link to comment Share on other sites More sharing options...
Cybernoid Posted October 4, 2004 Share Posted October 4, 2004 Good work! Gotta start some more music editting... Quote Link to comment Share on other sites More sharing options...
