Sign in to follow this
Nukey Shay
F8 bankswitch question
The ORG for bank 2 is wrong. $2000 is TIA address space. use $3000 instead.
Personally I prefere $D000 and $F000 for ORGs Because there are more '1' bits in it (all bits in an empty EPROMs are '1' and every '0' bit need to be programmed).
When I used $3000, it created a 12k bin that didn't work. I'm using RORG's paired with ORG's to compile the binary. With the RORG's I use the $D000 and $F000 in the first and second banks.
Well, i can't find any problems.
All 3 versions work just fine on my cart. I switched on and off
about 25 times for each version and they always start fine ...
Can you explain a bit more detailed what happens on your device ?
Kroko
Kroko
I don't have immediate access to EPROMS or a burner, so I don't know. The person who tested it used real hardware, AFAIK. I'm just using the emulators, which run just about anything you throw at them.
Here's what is still happening:
"Well, I get the exact same reaction from all three of your most recent
bins. Here's exactly what happens. 95% of the time, the EPROM works
fine on the first try. If I take the cart out and put it back in, about
half of the time the screen garbles. The ghost stays constant in the
back, but the lettering blinks on the left side and doesn't show up on
the right side. Also, random ghosts blink on the screen. I can get
into the first and second games, but the dot is split in two and all of
the maps are different. The game hangs if I try to get to the third
game.
If I take the cart out and insert it again after the garbled screen,
the cart works again about half of the time. Thoughts?"
hm ... not really but could you try to make a little delay
loop before you do the first bankswitching ? Give the console
and the cartridge a little time before you do the first bankswitch
after startup.
Try using the same opcode after the bank switching in both banks.
Look through the source for LD instructions that are missing the # sign.
I still think its a problem that only occurs at startup. A wrong initialisation of something. I don't think the bankswitching itself has a problem, or it would crash all the time. So its most likely that some timing issues of the console or the cratridge that can sometimes happen at startup are the problem. I think using the same vectors in both banks (like described above) is something that could help, in case the VCS is fetching the reset vector from different banks during startup of the cartridge.
But why should that lead to problems that occur only 5% of the time during startup ?
I suppose that was meant as a general hint, as this is a very "popular" error.
Thanks for all the ideas.
I've changed the bin: V2217
added 1 nop at the start of each bank for possible Atari hardware delays
added more (redundant?) info to start vectors due to possible start up problems
I wish I had an EPROM burner and the know-how to make a cart to test this on real hardware. Can anyone test this? My EPROM info source is gone for the weekend. If this binary doesn't work on a VCS cart, I'm seriously thinking about sponsoring a programming contest (this problem is driving me slightly crazy): If someone can solve the problem of why the program is not initializing properly on an 8k EPROM, I would gratefully send them a cart and manual as a prize. I would post the source, too (which would reveal the secrets of the game. :( I wanted to wait a while before posting it).
8kha2217.zip
I tried the original version on my multicart. I ran it 10-15 times from each bank didn't see any problems.
I'm having trouble understanding how removing the cart from the console could cause a problem related to the programing. Your program doesn't know if you turned it off and unplugged the cart or not. You couldn't check that if you wanted to.
Dave
I have a feeling that the code at the end of the banks is the culprit:
       ORG $1FF8
      RORG $DFF8
      .word 0,0,Bank1Start,0
       ORG $2FF8
       RORG $FFF8
       .word 0,0,Start2,0
should be changed to:
       ORG $1FF6
      RORG $DFF6
      .word $FFFF
      .word $FFFF,Bank1Start,Bank1Start,Bank1Start
        ORG $2FF6
       RORG $FFF6
       .word $FFFF
       .word $FFFF,Start2,Start2,Start2
Plus I added an extra NOP at the start of each bank.
Dave
Apparently 8k carts can start up in either bank, so the old code was causing problems when starting in the bank with the faulty coding for Atari hardware only; it doesn't show up in emulators (plus, hardware problems don't help either ;) ).
The one I tried was the first one listed 8kha2-v08.zip.
On my multicart I can tell it which bank to start in. I made one entry to start in bank0 and one to start in bank 1. I didn't see anything wrong with either one.
I'm not sure what is causing the problems since I'm not the one doing the actual testing of the carts and hardware. Since it seems to work starting in both banks with the older version, it is probably a hardware problem or an incompatibility in the hardware with the coding. Is the multicart or krokodile cart loading the bin on a six switcher properly? I'm strongly suspecting that the new multicarts work better (= more compatible with the bin code) than the EPROMs, but I'm just speculating because I don't understand the specs and electronics of the systems.
This is out of the realm of bankswitching, but would omitting the SEI and CLD instruction at the reset cause start up errors in a six switcher and not in a four switcher? :?:
Yes it does! (answers own newbie question :P ;) ) Problem solved. Atari hardware seems more finicky with regular cart EPROMS when bankswitching , and six switcher hardware is VERY finicky with code. Thanks everyone for helping me out! :thumbsup:
