I was skimming over some old messages in csa8 when I noticed someone asking about the OS ROM source code. Someone pointed to a 6 meg PDF of an Atari publication with a listing of the source. Someone else whined about it being a grayscale PDF file with the listing sideways, and that he couldn't do anything with the PDF. So I downloaded it, found that Preview on OS X was perfectly capable of saving a rotated version. Even more, I found that Omnipage Pro X had no major complaints about it, other than automatically rotating most of the pages to upside-down.
So I OCR'ed it, then spent a couple of evenings cleaning up the listing. I even got it to assemble (after doing a few search 'n replaces to get around the assembler syntax it used) to something much like a ROM file I had. The comments may still have a few errors, but it did seem to assemble correctly.
The differences between it and a ROM file I had were 1) the floating point and character set regions were not included, 2) the reset/interrupt vectors were missing, and 3) there were some patches that may have been made to improve emulator performance. After adding the code below, I got it to match the top 8K.
 .ORG  IHINIT+$12; $E6E7
NOP
NOP
NOP
.ORG  $E90B      ; not defined above
.BYTE $66,$66,$7E,$66,$00,$00,$7C
.ORG  *+3; JMP SETVBL
.BYTE $66,$7C,$00,$00,$3C,$66,$60,$60
.BYTE $66,$3C,$00,$00,$78,$6C,$66,$66
.BYTE $6C,$78,$00,$00,$7E,$60,$7C,$60
.BYTE $60,$7E,$00,$00,$7E,$60,$7C,$60
.BYTE $60,$60,$00,$00,$3E,$60,$60,$6E
.BYTE $66,$3E,$00,$00,$66,$66,$7E
.ORG  $EDE8     ; not defined above
.WORD $8524
.ORG  PWRUP+9   ; $F12E
.JSR  SPECL+5   ; $F244
.ORG  SPECL     ; $F23F
CMP   #$D0
BNE   HOWMCH    ; $F25F
RTS
.ORG  HOWMCH+8  ; $F267
BNE   SPECL+4   ; $F243 (=RTS)
.ORG  HOWMCH+$15; $F274
JMP   SPECL
.ORG  CLRCHP+9  ; $F283
NOP
NOP
NOP
.ORG  BELL      ; $F90A
RTS
.ORG  $FFF8     ; 6502 vectors
.WORD PIRQ,PNMI,PWRUP,PIRQ; $E6F3,$E791,$F125,$E6F3
a800ossrc.zip
And I'm going to go ahead and say that I know someone has probably already done this, but I went ahead and did it anyhow because if someone had, then nobody who knew about it said so in that thread. And I felt like doing it.
I definitely know others have disassembled and commented it on their own. I don't even have to look, it's just natural that someone would have done so. Well, that's nice, but it's no substitute for the historical preservation of the original source code.
I thought that they were asking for the XL source code. Which AFAIK was lost and never found till now. But, let me dream, might be in the VAX that Kurt recently got!
The source code you list (800 OS-B) is widely available in hardocpy as part of the "Technical Reference". Some dealers still have them brand new, and they show often at Ebay as well. But it is nice to have an OCRed version, thanks.
It doesn't include the floating point because it is(was) not by copyright atari, but by OSS instead. This is because the FP is actually part of Basic, and was included in the main OS because lack of space in the cart. The source was published by OSS along with the souce of Basic.
The interrupt vectors are modified for a LINT version, this is explained in the header of the source.
Yes, this is the OS B source code from that tech ref.
And where else can you get such gems as:
INTEMP: .RES 1 ;IAN'S TEMP (RENAMED FROM T1 BY POPULAR DEMA
and...
; DRAW -- DRAW A LINE FROM OLDROW,OLDCOL TO NEWROW,NEWCOL
; (THE AL MILLER METHOD FROM BASKETBALL)
Thanks!
I think Nir Dary had (has ?) it.
It has (had) the actual source with the original comments, or just a disassembly?
If I remember right he mentioned he would have the fully documented listing (from Atari Labs). Perhaps Nir can answer this question by himself as he is a member of this board...
OKay, here is the source to the XL OS Rev5, this should cover most of the needed information for everything up to the 800XL, I know I have the patches and sources to the 1450XLD "TONG OS" someplace...
Curt
OS_Rev5.zip
This is FABULOUS ! Thanks a lot Kurt.
Do you happen to have older revisions? Rev2 would be the best because that's the one in most (all?) standard XL/XE systems.
I will post on my Computers section this coming week all of the various versions I have on file.
Curt
962719[/snapback]
And here, years later, is an assembled binary of this OS revision:
... still waiting, Curt ...
Edited by Kr0tki
Which is the one you assembled?
Quote mentions "Rev5" but your file name reads "1r4" (1984, crc32 "D0C84956")
I don't know why the original archive is called "Rev5" - the ROM signature in the source clearly states it's CC000001 Rev. 4 (1984-09-06).
Confusing. The Rev. 4 I have is dated 1987 (crc32: 1EAF4002) and is nowhere the same as the one you assembled.
Not really confusing if you know the details. The above "Rev. 5" OS was not used in any production machine. OS versions BB000001 rev. 3 and 4, that were featured in the XEs and XEGS, were not developed from the above OS but were modifcations of the earlier BB000001 rev. 2, which was mounted in the 600/800XLs.
The confusing part is that Rev. 4 is copyright 1987 while the discussed "Rev. 5 " is copyright 1984. That's what's mentioned in the code. Of course such a situation is possible, just not logical.
How I'm supposed to archive it :-))
