AussieAtari Posted August 9, 2006 Share Posted August 9, 2006 Does anyone know where I can lay my hands on a power adaptor for an Apple IIc, apart from eBay? Also, do the adaptors take 110V - 240V or will I have to get a specific adaptor for 240V? Cheers. Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted August 9, 2006 Share Posted August 9, 2006 (edited) Here is the pinout [font=Courier New] From the Apple //c Technical Reference Manual Section 11.2.2 The External Power Connector The external power supply is attached to the internal converter by means of a 7-pin DIN connector. The connector pins are identified in Figure 11-1 and Table 11-3. Figure 11-1 External Power Connector . --+ +-- Pin# Signal . / 7 |_| 1 \ Pin 1 Not Connected . | 6 2 | Pin 2,3 Signal Ground . \ 5 4 3 / Pin 4 Shield Ground . \_______/ Pin 5,6 +15 VDC . Pin 7 Not Connected Table 11-3 External Power Connector Signals Pin# Name Description 1,7 -- Not Connected 2,3 Ground Common Electrical Ground 4 Chassis Chassis Ground 5,6 +15 +15-volt DC input to converter [/font] I dont remember if its takes both 110/220V, but I know the US power connector is stuck on the brick. Edited August 9, 2006 by Almost Rice Quote Link to comment Share on other sites More sharing options...
