Ross PK
What's the latest Atari related thing(s) you've bought on ebay?
While waiting for the new run of the Incognito, I was looking for a matching printer for my 800. You can't find an 820, 822, or 825 for sale here in Europe.
So I am glad I found this boxed KX-P1081 on Ebay. Back in the day I had a Panasonic KX-P1091i with my ST, so I know these are very reliable and Epson compatible.
Just tested it and it works fine. Looks a bit patchy on this Ebay photo, but after some cleaning it looks fine.
  • Like 4
I bought a 1050 Floppy drive, a new Dos 2.5 floppy/manual & a 1010 in need of a new belt. Not even sure why I got the 1010 except maybe because I have the dataset with my C64 lol...
So now I'm only missing the centronic interface.
I now have both a C64 setup and an Atari setup. This should cover most, if not all, my 8bit computer needs.
Sadly the Atari computer line wasn't all that popular in my province so I don't expect to find a 1,000 floppies lot like I did this summer for the C64. If I ever do, I'll get an Atarimax to rip them to files.
On 9/29/2019 at 10:02 PM, hueyjones70 said:
An Atari SF354 disk drive, I believe I can convert this one to an 8-bit drive.
How?
How?
Dropcheck makes a board and there‘s a thread somewhere around the 8-bit forum.
Gesendet von iPhone mit Tapatalk
My first printer, I am very jealous
41 minutes ago, hueyjones70 said:
Check out this thread. IDEA:External Atari ST drive transformed to 8-bit (XF551 internals).
Thanks!
I got a 1050 dirt cheap a couple of days ago, knowing it needed work. I guess since it is nearly 2020 it is time to learn to work on them :)
In the past week two mint condition NTSC 400's sold on ebay. One unopened went for $500 the other opened box went for a little over $400.
However there was a third unrecognized by the seller that was mint. The single poor quality low resolution photo didn't help. That is the one I got and saved ~$350. Works %100 so far as I can tell. No box though. His grandparents bought it for his uncle and it was stored in a closet for many years. Judging also by the included NOS power supply still being coiled by Atari except for one 10cm of the barrel end of the wire removed from the still tied (by Atari) twistie tie, I think it was used once and put away. There was some black gunk from the cart shield adhesive that made some mess (but not in the cart tunnel thankfully). Cleaned the gunk up as well as I could without spreading it everywhere and re-glued the shield. The spacebar has a tiny bit of black remaining (see photo) which may yet clean off.   I thoroughly clean A8 acquisitions but this one didn't need it, bar the tar gunk.
I had no idea he would accept my low offer so I 'bought now' on another 400 which is yellowed and well used but has an undamaged case.
Edited by Sugarland
  • Like 10
8 hours ago, _The Doctor__ said:
The PAL 600XL is such a nice little Atari... everything on it except it needs an easy memory upgrade...
Antonia is an easy memory upgrade plus multiple OSes, Lotharek sells a 64K one for 16 EUR and IIRC @tf_hh has a 512K SRAM that works.
Deals like that are nice. a POKEY chip alone costs about that from BEST/B&C.
I was the only bidder on a 130XE keyboard and won for 99c, (plus $18 shipping). It's not too yellowed, sold 'untested' but I found it works perfectly.. Only it's missing a W key.
A PAL Atari 800 (sold untested). It almost works as well! The space key does not work but otherwise seems ok.
Edited by Lardo Boffin
Added PAL to text.
space bar not working is almost always a leaf/bad solder joint issue... sometimes the contact falls out completely lost forever, then you have to fashion your own...
eBAY.DE 58 EUR 800XE broken , powerswitch stuck.
2101058764_800XEbrokenswitch.thumb.JPG.86b9fd9106ee043c35c4fc46acaf34b4.JPG971144260_800XEshield.thumb.JPG.b6508f7102a42c5ec4b427655ecf5f71.JPG1518301973_800XEinnards.thumb.JPG.7aca22c650bad9e07de81707ad8fa425.JPG
So I took one from my Parts-Only 130XE and replaced it and tadaah.
I need to clean/brush the keys since they actually aren't that yellowed , just really dirty, the inside also had a lot of dust.
But the top and bottom case still have their almost original grey color
  • Like 4
It's been such a long time that I can't even remember. I think it might be a copy of Dark Chambers for the 2600 that I've still got sealed in the attic. Pretty sure I bought that when I was still living in Cardiff more than 10 years ago.
As for the 8-bit, I probably have to go even further back. Possibly Archon on cartridge.
One day, when I have time and money to spare ...
I've bought a second 1050 in a crappy box, but complete and tested. Now my setup is really complete. Well minus the 1010 but that isn't a priority. The drive isn't too yellowed but since I just spray painted the first one (it was beyond yellow, it had turned orange), I think I'll give it the same treatment. I use Canadian Tire bought Rust-Oleum 2X  "rustic white". The color is really close to the original and at least now it's uniform. I also did the 800XL but while reassembling the cart flaps, I over tightened two screws and ended up with two small dimple, barely visible but I know they're there, on the top.
